Copy automation project rules to a project in another Cloud
sophie.jim May 12, 2022
Hi there,
Is there any way that I can copy or export all automation project rules to another project in another cloud?
We have over a hundred rules and it will be really time-consuming to create it one by one. Thank you.
John Funk
Hi @sophie.jim  - Welcome to the Atlassian Community!
In the instance that has the rules you want to copy, go to Settings > System > Global Automation
Click on the 3 dots menu in the upper right and choose Export Rules
Then go to the Target instance and do the same thing, except choose Import Rules.
Then follow the prompts.
Hi @John Funk , yes the way suggested allows me to export all the rules. Is there a way that I can filter out the rules of a specific project that I want then import the rules in another cloud? Thank you.
Like John Funk likes this
John Funk
After you do the export, you can select which rules you want to import into the new instance. You don't have to import all of them even though all of them might get exported.
sophie.jim May 15, 2022
Hi @John Funk , thank you for the suggestion. May I know how I can select those rules that I want? I have the JSON file with me but not sure what to do. Thank you.
John Funk
Do the import in the second instance. There you will see a list of the rules and you can click on the ones you want to import.
Fabio Racobaldo _Herzum_
Hi @sophie.jim ,
welcome to the Atlassian community!
Currently there's an open request for that feature https://jira.atlassian.com/browse/JSDCLOUD-3259
Please vote it in order to keep up-to-date about it.
Workaround :
  1. go to the project with the rule you want to copy
  2. copy rule in the same project
  3. go to Global automation rule administration and select copied rule
  4. edit project scope to target project for selected copied rule
Hope this helps,
Fabio
