Dear community,
I have an automation that seeks to be able to "copy" the data from a drop-down list field (it is in an epic) and paste it into another project linked to this one through the "parent", the destination field is called the same way (Site Type).
I have been trying to get this done for a few days now and I have not been able to, in the automation log it appears that it does it but when I check the ticket of the parent related to the epic, the field appears empty, can you help me figure out where I am failing? I attach an image of the log and the rule.
How did you configure the Edit Issue field action ?
Hi
You should use {{triggerIssue.Tipo de sitio}} not {{issue.Tipo de sitio}}.
When you do the branching issue become the Epic so you copy nothing to teh field.
Regards
Florian,
Perfect¡, this fixes the problem. It works now, thank you very much!
Hi, I tried to replicate your automation but I get the same result as you do, the parent that is of another project have been edited according to the logs.
But!
With this alternative writing I got the data to appear at least in the issue history;
As you say, the log records that it does something... but I don't see anything reflected in the linked project.
I don't know if it's a jira issue or something I'm not seeing.
I too believe that is some kind of bug. My issue history of the parent issue shows changes, not the field did not changed even once. The only logical explanation is some kind of problem on the Atlassian side of mess.
