Copy last comment to custom field, limit to 200 Characters and add link to issue
Susan Cain January 22, 2025
Hi, I was able to create a custom field to copy the last comment made on the issue to the field.  However I continue to get an error
(Current Status can't exceed 255 characters (customfield_10183))
I am trying to limit the returned value to be the first 200 characters and return a message at the end of the text when it is over 200 characters.
So far I only have this code.
{ "fields": { "Current Status" : "{{comment.body}}" } }
2 accepted
3 votes
Mikael Sandberg
Hi @Susan Cain,
You can limit the comment by adding this to the end of it: .abbreviate(200)
This will limit it to the first 200 characters.
January 22, 2025
Hi @Susan Cain -- Welcome to the Atlassian Community!
Adding to Mikael's suggestion...
Comments may contain special formatting, mentions, etc.  If you want to parse that out (such as converting mentions from ID values to display names) consider adding text conversion to your field before abbreviation.
For example:
{{comment.body.text.abbreviate(245)}}
Like Mikael Sandberg likes this
This is what I ended up with.  Thank you for your expedient assistance!
{ "fields": { "Current Status" : "{{comment.body.abbreviate(245)}}" } }
