Copy logged time from issue to linked issue
Simon Huprich
I got the following situation:
The Dev - Team has to clone an issue to a specific development project.
To accomplish this, they use a manually triggered automation rule.
(clone, comment, link issues).
When they work and log on the cloned issue, it would be necessary that the logged time got copied to the original issue.
So, how do I configure the automation rule that every time when the cloned issue is updated (or work is being logged), this value gets copied to the original issue. What configuration should I use in "Additional fields" (see image).
Thank you very much!
Greetings
Simon
Trudy Claspill
December 14, 2022
Hello @Simon Huprich
You can't use the Edit action to log work on an issue. You need to use the "Log Work" action.
I recommend that for this rule you instead use the Trigger for "Work Logged" and then use the Action for "Log Work". That will give you the ability to get the detail information about the specific work log entry being made on the copy of the issue and then use those details to log work against the original issue.
Simon Huprich
Hi Trudy,
Thank you for your answer.
So, I tried a little bit, and finally I came up with this solution.
Greetings
Like Ramiro Ocampo likes this
Nagapratap Mahanandhi September 7, 2023
Hello @Trudy Claspill ,
Is it possible to sum up the logged issues? I have a requirement that I need to sum up the logged issues from all the linked issues.
EG: main issue - A
 LINKED ISSUES : B AND C
SUM A = A+B+C
Naga
Trudy Claspill
September 7, 2023
Hello @Nagapratap Mahanandhi
Please start a new Question to get assistance. The Question is almost a year old and already has an accepted answer. If this post is relevant to your new Question include a link to it.
Like Bill Sheboy likes this
