Hello everyone !
We are a somewhat new team on Jira and currently using the new Jira Software (instead of classic).
Context
We wanted to have 2 boards (1 for refinement, 1 for sprints), but the new Jira Software does not allow that. So we created a new project for our refinement board.
What we do is that when an issue is moved in "done" in the refinement board, it is cloned in the sprint project backlog.
Problem
The problem we face is that 2 information are not cloned with the issue:
Did anyone face a similar problem or does someone have some kind of solution to this problem?
What we tried
We already tried to get the story points custom field id and add it to the cloning action options, but we did not manage to make it work.
Any help is welcome =)
Changing my profile language did not change the text here, but the key words are similar enough to english I think.
Rewinding back to the original problem, have you considered an attempted to create kanban board based upon a filter i.e. your project and simply setting the location of that board to your profile and then adding a link on the side bar of your project to that kanban board? This would affect give you the two kanban board or kanban and scrum board that you desire. In other words there is a manner of having a secondary board.
Thank you for your answer =)
It's the first time I hear about something like that so I will look into it.
I just tested and it works fine. For some reason this method continues to be ignored in the Community.
I have documented in an article here - Multiple-boards-in-Business-and-Team-Managed-Projects?-You-Bet!
Thank you very much!
For our specific problem, we created a filter for our project with tickets containing the label "to refine".
Then we created a board based on this filter as suggested in your solution.
We can now manage non-refined issue in this boar. I added an automation rule: when an issue is in state "done", then remove the "to refine" label and add the "refined" label. This will allow the ticket to be removed from this board and be ready for our next sprints =)
Hi @nadibenheigvd ,
what I would do usually is have one Kanban board for the refinement, and a Scrum board for the sprints. Having 2 projects is just adding a lot of complexity for no real reason I think. It would also double the amount of attachments and storage, not a good idea on the long term.
You should create a company-managed project, this way you can have multiple boards in a single project and move issues between them.
Let me know if this helps,
--Alexis
But you can have multiple boards in TMP, right? I guess I need to give it a try again maybe something is changed since I last did it. I know I have one current TMP that does have multiple boards.
Well we tried to do what you said (I don't know about the company-managed part) @Alexis Robert, but it looked like having 2 different boards in the same project was only available for the "classic" Jira software. That is why we created another project since we changed our version of Jira software to the new one (excuse me I don't remember the exact names).
If you can give us a hint on how to create a kanban board in the same project (where we already have a scrum board) it would be much appreciated =)
I look into it a little bit now again.
Thanks in advance!
