Hi community.,
Is there any way to copy users from one group to another in cloud istance?
Thank you!
Hi @Marco Munari OverIT -
I'm afraid Jira does not have an Inbuilt functionality to copy users from one group to another. Though there are two feature requests that would allow you to configure it:
- Improve Add Users To Group Functionality
As a workaround, you can create a REST API Script to bulk add your users. These would be the exact steps:
1 - Navigate to your User management > In the Users tab, click in the button "Export Users"
2 - Select the group you want to export the users from and finish the export:
3 - Create a new group in Jira
4 - Create a script using the post command in Jira Cloud REST API to add those users to the new group you created, preferably using a practical text editor that will place that call together with the users you exported:
POST https://yourdomain.atlassian.net/rest/api/3/group/user
Thanks for support,
one solution might be this https://marketplace.atlassian.com/apps/1218266/csv-user-importer-for-jira?tab=overview&hosting=cloud
MM
Hi @Marco Munari OverIT ,
there is an open request for that https://jira.atlassian.com/browse/JRACLOUD-42264
As workaround you can put in place a script that use rest api to retrieve/add user in a group.
Fabio
Help us plant more trees
