Hi everyone,
I need to copy a project layout (no data) from the external Server-based JIRA instance to our internal Cloud system. There is absolutely no connection between those 2. Could anyone suggest a best way to do so, outside of doing it manually? I'd greatly appreciate it.
Hi @Gregory Kremer and welcome to the Community!
If you're not going to copy any data, doing it manually will probably be the fastest option.
Thank you Walter. I wasn't aware of any fast options either, but was hoping that someone had some trick up his/her sleeve. I'll keep this thread open for a little while longer just in case.
And just for the record. I am not new here - I've been a member of this community for many years. I've just changed jobs, hence had to re-register under the new email address.
