Copying field's value from Task to Sub-task
Rafal Sojka
Is it possible to copy a value of field from Task into Sub-task while creating this sub-task and making this copied value read-only ?
Please advise if you have any idea.
Thank you,
Rafal
Haddon Fisher
December 14, 2020
The quickest and best solution I can think of would be to use a ScriptRunner scripted field living on the sub-task to show the value of the field from the parent.
- It's inherently always going to be accurate because it's just a view of the parent, so you don't need to worry about listening for changes and then keeping them in sync.
- I am not sure there's a way to make fields conditionally read-only that doesn't involve ScriptRunner anyway.
'Automation' would allow you to push data around, so if you cared less about the field being read-only, that could be an option as well.
December 14, 2020
Hi @Rafal Sojka
Adding on to what @Haddon Fisher  suggested...
One consideration is do you need the task and sub-task values to remain in synch, or can the sub-task value change to be different later.
If it can change, consider using an automation rule to copy the value and so it will remain independent for edits.
Best regards,
Rafal Sojka
Thank you @Haddon Fisher and @Bill Sheboy , really appreciate that.
Finally, i decided to use JMCF plugin since it provides a scripted date field. I implemented a short Groovy script to copy a value from the parent issue.
Like • Haddon Fisher likes this
