Copying (or syncing) custom field drop down from Epic to Story
bmacd
Hi team, would really appreciate some help with this one.
We have a custom field "Work Type" which is a drop down with four options.
I want to set "Work Type" on an epic and have all the stories/bugs/tasks in the epic set the same value.
I've tried a couple of ways to do it but it doesn't work. I have a feeling it's because it's a drop down field but I'm not sure.
Method #1:
Transition issue
Unknown fields set during transition. Field may not be on transition screen. Fields ignored -
Work Type (customfield_12189)
Transitioned issues to
Backlog
Method #2:
Action details:
The following issues passed:
Project-734
Error editing issues
ATLAS-734 (Specify a valid 'id' or 'name' for Work Type (customfield_12189))
2 accepted
bmacd
I used the link here to figure it out. This is a screenshot of the solution that works.
https://community.atlassian.com/t5/Jira-Software-questions/Copy-field-value-from-Epic-to-child-issue-with-automation/qaq-p/1421943
Earl McCutcheon
June 1, 2022
Hello @bmacd ,
Thanks for reaching out to the community and there is a really good breakdown on this in the following thread with some screenshots and examples:
The main thing to look at is the branch rules which act as a separator between the actions performed on the parent and child issues.
Earl
bmacd
Thanks Earl, I got the solution from that link.
Like Earl McCutcheon likes this
