I am using MS team Jira cloud bot with SSO but the issue when i am trying to create the issue , the system always shows Could not find project with key APS
How can we solve this please?
I'm prety convinced that I've figured out the issue as: current user doesn't have access to the first project in the Jira project list that the Teams app fetches.
I don't think you can access the request, but I mentioned your post in it.
So, as a reference, this is the support request: https://getsupport.atlassian.com/servicedesk/customer/portal/47/SPSP-17484
I'll try to remember to keep you posted on the status of this request.
Hi @Hamdien A. Bishara ,
Bug (+workaround) got registered: https://jira.atlassian.com/browse/JSWCLOUD-21245
Add yourself as watcher if you want to get notified upon solution.
