Count of automations executed - where can I monitor
eleanor kerman
I receently received this warning
At the current rate you will exceed your monthly execution limit. Upgrade your plan to increase your limit and continue automating. Upgrade
I would like to monitor the number of executed automation, how can I follow the number of automations. I need the details to present.
John Funk
Hi Eleanor,
If you go to the master list of rules (following Dave's guidance above), you should see these menu options:
Click on Usage to see the number of executions.
July 12, 2021 edited
Hi @eleanor kerman
Yes, and...to what was already suggested:
You may be reaching your limit on global rule executions, or have a project-scope rule that is running too frequently/consuming too many resources.  Please consider discussing with your site admin to set up a monitoring rule that will email people earlier when such situations occur.  Here is the trigger to check that:
https://support.atlassian.com/jira-software-cloud/docs/automation-triggers/#Automationtriggers-Servicelimitbreached
Best regards,
Dave Bosman [Realdolmen]
July 11, 2021
Hi @eleanor kerman
go to 'automation' in the backend where you can find and manage all your automation rules
Cog => system => Automation rules
Click on usage and there you can find what you are looking for
Regards
Dave
Register now
