Create Component button missing after creating first Component
Maurice Huellein December 1, 2023
Hi all,
I am using a company managed project in Jira Cloud and tested the use of "Components" (project settings -> components). As a site admin I have successfully created a list of components before, however, I wanted to replace them with new items.
After I deleted all of them, the icon in the middle of the screen appears that invites me to create the very first component. Using the button, I fill in the details and there is my component. Problem is, there is no way anymore to create another component. I expected the "Create Component" button to be in the upper right corner, but there is nothing.
I tried another browser, cleared cache, checked my user privileges ... same issue.
Mikael Sandberg
December 1, 2023
Hi @Maurice Huellein,
This is a known issue and Atlassian is working on a solution for it.
Thanks for the speedy reply, @Mikael Sandberg !
Like Mikael Sandberg likes this
Andy Heinzer
December 1, 2023
Hi all,
We posted a statuspage update about this problem over in https://jira-software.status.atlassian.com/incidents/dqp20lxd0ndj
It appears that this has been resolved now.  Sorry for the inconvenience.
Andy
Jack Brickey
December 1, 2023
@Maurice Huellein , welcome to the community.
There appears to be a regression related to components. I saw this being discussed in a slack channel this morning. I was just playing with it and there seems to be something fundamentally wrong when trying to create a new component. If I go into an existing issue and click on the components field and attempt to add a new component there it takes me to the component screen but again no create component capability. I would recommend that you reach out to Atlassian support and report this issue.
@Inactive Stephen , just an fyi.
