Hi Everyone,
I want to create a Graph in Dashboard in which
i have to see two filters
in Y axis the Task counts
and in X axis "Assignee names"
in this Below image for e.g i have used "Average age chart"
so that we can have a picture of which assignee as done with how many Tasks
This is what i want to achieve
kindly provide any solution like any JQl query need to add or anything else
Hi @Yash Raj
Not sure that this is exactly what you want, but create a filter something like:
Project = ABC and issuetype = Task
Then create a dashboard and add a two dimensional filter gadget
Then use Assignee for one axis and Issue Type for the other.
Try that and see what you think.
Hi @John Funk
Thanks for your Quick Response
here's the Output of the answer
its still showing the days and dates in Graph rather than "tasks count and Assignee"
Why must it be a graph? I guess you could use a Pie Chart instead if you need it graphically.
But you can also click on the number for each Assignee to see the list of all of the issues.
Hi @Yash Raj
If the chart and/or table that John suggested do not meet your need, I do not believe there are any built-in gadgets that will display those fields as a bar chart.
Instead please look at the Atlassian marketplace for free or paid addons for reporting/dashboards. If you do not need this in a dashboard, you could also use the Atlassian provided Excel or Google Sheets addins to run your filter and build the chart yourself, or just export the data for spreadsheet-based chart reporting.
