Create a classic project based on a "template project" in this Jira New Version
Daniel Rios
Hi
We've been creating classic projects based on a "model project" with customized incidence types and flows for years, and today using the "create new project" option I only can see the screen for selelection between a lot of prefab templates.
Some one knows where can I find the old option of creating a new classic project and select a previous project as a template?
Thanks in advance.
Daniel.
2 accepted
Callum Carlile _Automation Consultants_
Hi @Daniel Rios As soon as you click 'Use this template' for any of the templates, you will see the screen you usually see where you enter the project name, key, and whether or not you would like to share settings with an existing project.
The main change with this new view is that there's more emphasis on selecting a template, but the old functionality is still there
Daniel Rios
Perfect! Thank you very much for the advice.
John Funk
Hi Daniel,
Click on the Jira Software option under Products on the lower left side.
Daniel Rios
Hi John,
Maybe I'm missing to do somethig, because when selecting the Jira Software option I can see only the same screen with 3 options (kanban, scrum and incidence management) I mean, I can´t find de "classic project" option that we used until recently.
I hope it's something I'm not seeing and you can give me some advice.
Thank you!!!
John Funk
Choose Kanban or Scrum and then you will see Team-managed or Company-managed project options.
Classic Software projects are now called Company-managed projects.
Daniel Rios
Thank you very much John. I got it :)
Like John Funk likes this
Kathy Hart
They have added another layer of complexity. Now you have to select between company managed and team managed as well before you get to tell them that you don't want any of that, you just want to copy an existing project.
With the new change to Create Project, you have to do this:
1. Projects > Create Project
2. Pick any template.
3. Click "Use template"
4. Click "Select a company managed project"
5. Select "Share settings with an existing project"
6. Select the project you want to base it on.
To move the Share Settings option back to step 2, please vote on this suggestion for Atlassian.
https://jira.atlassian.com/browse/JRACLOUD-77209?jql=text%20~%20%22existing%22%20ORDER%20BY%20updated%20desc
