Hey,
I want to create a new level above epic called Theme or epic Group. Like the story is under epic, I want a new level above Epic.
How I create that?
Maya
Hi Maya,
You will need to have a Jira Premium Subscription to be able to do that. You can try that for a free trial and see if it works for you. The product is called Advanced Roadmaps. Here is some information on how to add additional levels to the hierarchy.
