I have a set of 10-15 subtasks by default for every Issue which is created.
So whenever i Create a Issue I want the sub tasks to be automatically created by defaults using automation.
How can I achieve this?
Hi Swaroop,
You can see how to do that here:
https://www.atlassian.com/software/jira/automation-template-library/rules#/rule/112180/26549810
Hi @Swaroop Bangera ,
Yes, this can be achieved. Please follow below steps
Go to Project settings --> Automation --> Create new rule
Select trigger as Issue created
If you need any conditions, ad them under "If: Add a condition"
In JQL section, type your query for which tickets you need sub-tasks to be created and click Save
Select Action --> Create Sub-Tasks. Fill the subtask descriptions and go on adding the required sub-tasks to the list
Thank you I was able to create this automation
It’s Aleksandra from Deviniti and after reading your post, I think you may find our app handy :)
With the help of Issue Templates for Jira, you can create a repository of reusable templates to cover all the repetitive tasks in your projects. Such templates can be used to create new issues in Jira (via the Create issue from template button), but also in Automation.
So if you need to automatically populate a set of sub-tasks, you could prepare a template and then use our post function to apply it when a new issue is created in the project. You could also use it in automation if more appropriate.
Thanks to that, each time a new issue is created, the subtasks and their field values defined in your templates will be added immediately.
Hopefully, you will find it useful!
Aleksandra
Read the story
