Create an Issue with Epic as parent using REST API
Vijay Gopu June 18, 2020 edited
I am able to create an Epic using REST api. But unable to create issue under the created EPIC? How do i do this?
EPIC: [Success]
POST : /rest/api/2/issue
Request:
"fields": {
"project":{"key": "JIRA PROJECT"},
"summary": "Customer : Customer Name",
"description": "[TEST] : Creating of an issue using project keys and issue type names using the REST API",
"issuetype": {"name": "Epic"},
"customfield_10008": "Customer : Customer Name"
Issue: [Failed]
POST : /rest/api/2/issuetype
Request:
"fields":{
"parent": {"key": "JIRA PROJECT-1336"},
"summary": "Application Name: Customer Name",
"description": "Don't forget to do this too.",
"issuetype": {"name": "Project"}
Exception:
{    "errorMessages": [        "Unrecognized field \"fields\" (Class com.atlassian.jira.issue.fields.rest.json.beans.IssueTypeCreateBean), not marked as ignorable\n at [Source: org.apache.catalina.connector.CoyoteInputStream@344973c6; line: 3, column: 6] (through reference chain: com.atlassian.jira.issue.fields.rest.json.beans.IssueTypeCreateBean[\"fields\"])"    ]}
Also if i change the URI to /rest/api/2/issue then i get a different exception:
{    "errorMessages": [],    "errors": {        "issuetype": "Issue type 11100 is not a sub-task but a parent is specified."    }}
1. Why is that i am able to create the an issue under Epic using the user interface but not via the REST api?
2. Is this a permission issue or am i doing something wrong. I couldn't figure out. I got the full access for the project to create any type of ticket.
Please let me know.
Thank you,
Vijay
4 votes
Najjar _Innovura_
Issue in epic are not considered subtasks of epic
Jira has a Customfield named Epic Link
If you would like to create an issue under an epic, the child issue of the epic should have epic link custom field value with the epic key
Note, Parent is only used for creating subtakss
Vijay Gopu June 22, 2020
Hi @Najjar _Innovura_ ,
Would you be able to share a simple example on how to do this?
Thank you,
Vijay
Najjar _Innovura_
June 22, 2020 edited
curl --location --request POST 'http://localhost:2990/jira/rest/api/2/issue' \
--header 'Authorization: Basic YWRtaW46YWRtaW4=' \
--header 'Content-Type: application/json' \
--data-raw '{
    "fields"{
        "project"{
            "id""10000"
        "summary""something'\''s wrong",
        "issuetype"{
            "id""10000"
        "assignee"{
            "name""admin"
        "customfield_10102""JIRA-41"
In my jira instance custom field "Epic Link" id is 10102
Thank you @Najjar _Innovura_ . Apparently the customfield can differ is what i found based on this link here
What i received using the REST call is that "Epic Link" in my implementation is "customfield_10007"
URI: /rest/api/2/field
Response Snippet:
"id": "customfield_10007",
"key": "customfield_10007",
"name": "Epic Link",
"untranslatedName": "Epic Link",
"custom": true,
"orderable": true,
"navigable": true,
"searchable": true,
"clauseNames": [
"cf[10007]",
"Epic Link"
"schema": {
"type": "any",
"custom": "com.pyxis.greenhopper.jira:gh-epic-link",
"customId": 10007
Najjar _Innovura_
Yes epic link defers from instance to instance. your json should look like this:
"fields"{
        "project"{
            "id""10000"
        "issuetype"{
            "id""10000"
        "assignee"{
            "name""admin"
        "customfield_10007""EPIC_KEY_HERE"
Thank you @Najjar _Innovura_ I will give this a try.
Regards.
Vijay Gopu June 24, 2020
Works!
Naeem
March 3, 2022
@Najjar _Innovura_  hi, i am trying same, but i get this error
"Field 'customfield_10014' cannot be set. It is not on the appropriate screen, or unknown."
can you help me with this? thanks
Ben Upham
Ditto, getting same error!
Lukasz Kalemba
September 21, 2022
Same as above:
Field 'customfield_10101' cannot be set. It is not on the appropriate screen, or unknown.
Vijay Gopu July 15, 2020
Where is the answer to this question? Why are you deleting answers in this forum?
Vijay Gopu July 15, 2020 edited
@Jack Brickey Do you happen to know Where the answers and discussions on this topic have been moved to? Why am i unable to see the previous discussion?
Jack Brickey
@Vijay Gopu , No answers have been deleted. There was an issue with the application that should be fixed at this point.
@Jack Brickey Thank you very much for the clarification and looking into this. Much Regards
