Create an attachment via automated webhook to JIRA REST-API by providing attachment URL
Chris Fortmueller
JIRA does not currently support the copying of comments or attachments when cloning issues (see https://jira.atlassian.com/browse/JRACLOUD-5052). However, this is a requirement for us in certain cases. I am therefore trying to implement a similar feature to copy attachments via sending HTTP requests from Automation for Jira.
I have been able to do this via postman with the following configuration:
Can I also, instead of selecting a file in the second screenshot via the explorer, provide the JIRA REST-API with a file URL? If that would work, I could use webhook request in Jira Automation...
Prince Nyeche
March 29, 2021
Hi @Chris Fortmueller
Copying attachment from one instance to another or project to another is very possible via API. However using automation and webhook seems more like manual task would be involved rather than it being automated. i.e. how will the attachment url be extracted dynamically using automation and how would automation post the data back to another project or instance?
Chris Fortmueller
This is happening in the context of cloning an issue, so I would do it via the smart value {{attachment.filename}}.
You seem to have some other solution in mind for doing this?
Prince Nyeche
March 30, 2021
Ok, once you get the url for the attachment that's one step, how do you post back a binary data to Jira? What I'm thinking here is that using a webhook service, you can send the request there (which includes, the instance url, issue key, attachment url) and the webhook service will extract the file (authentication is needed for proper extraction) as binary data then fire another request to Jira attachment endpoint with a POST request of the binary data. That way, you get a copy of the attachment on another issue key.
Chris Fortmueller
March 31, 2021 edited
I was thinking along the same lines. But our IT Infrastructure doesn't match the requirements for hosting such a webhook service, since it would need to be accessible for the world via a DNS-Name/IP... For the moment, it seems I am stuck waiting for https://jira.atlassian.com/browse/JRACLOUD-5052... :/
Prince Nyeche
March 31, 2021
The alternative is to use an addon as suggested on one of the comment on this ticket JRACLOUD-5052
Chris Fortmueller
Thanks Prince, might give one of them a shot.
