Create error msg while changing the workflow status
Geethanjali S J
Hi Team,
We have an issue type called MBI under MBI we have child issues
The workflow for MBI is
To do - In Progress - Complete
If all the child issues under MBI is closed/Accepted we can move the status from in progress to complete
If any one of the child issue is not closed/accepted it should show an error message and we cannot move the status
Can anyone please help me how to do this.
Geethanjali.
Carlos Garcia Navarro
I know this is not the same thing that you're asking, but you could automate the transition of epics to done, when the corresponding tasks are done as described here: https://community.atlassian.com/t5/Jira-Core-Server-questions/Transition-Parent-Epic-to-done-when-tasks-are-done/qaq-p/1440449
Tinker Fadoua
@Geethanjali S J
Are you using any plugins? or you want this behaviour in Jira without the use of a plugin?
Best,
Fadoua
Geethanjali S J
We don't use any plugins and our instance is jira cloud.
Like • Tinker Fadoua likes this
Tinker Fadoua
When you want a message to display to users, you usually add a validator
Looking at the validators available in Jira Cloud none of them will apply to your case.
You will need a plugin so that you can add a script that will warn the users that there is a child issue still open, it is the reason Parent issue can not be closed
If you have any questions please let me know.
Best,
Fadoua
Geethanjali S J
We have script runner plugin may I know how we can do by scripting
Tinker Fadoua
Perfect you have the best plugin for your request. Let me get you the Script
Geethanjali S J
Please let me know the script this is for cloud
Geethanjali S J
Tinker Fadoua
Promise to send it tonight. I was very busy these last 2 days
Tinker Fadoua
@Geethanjali S J
Please check the following, it will help you with your request:
https://confluence.atlassian.com/jirakb/preventing-issues-from-being-closed-while-their-sub-task-are-still-open-724928276.html
Let me know how it goes.
Best,
Fadoua
Geethanjali S J
Actually we tried that but our requirement is not that
We are not creating sub task
We are creating Epic and Sub service issue type only under MBI by using parent link(MBI).
Tinker Fadoua
I am looking at the moment for a Jira Cloud repo created by an Adaptavist Engineer that has several scripts. May be few tweaks then it can work.
