Create insolated boards for each team
Rasha Farouk November 24, 2020
Hi every body
Please, did you try before to create insolated on parallel boards in the same project for each team in Jira?
I already isolated stories and each board has their stories only. But till now all boards can be opened by all teams.
I want BE(Back End) team only see his board. Also, FE(Front End ) team only see his board.
Also the road map to be visible to the administrators only.
Is that applicable at Jira?
November 24, 2020
Hi @Rasha Farouk
This question looks like it overlaps the other one you wrote:
https://community.atlassian.com/t5/Jira-Software-questions/Limitations-at-using-on-parallel-sprints/qaq-p/1541595
Would you please consider marking one of them as "answered" so responses are not split between the two?  Then you may mark the remaining one as answered once you consider it resolved.
Thank you, and best regards,
@Bill Sheboy Thanks so much. I did :)
Like Bill Sheboy likes this
Register today
