I'm trying to create issues in a Jira cloud project using rest api, but I'm not able to create as its throwing error "XSRF check failed". I'm using Talend Api tester. I'm not sure where it is going wrong. Please help!.
For authorization I gave my Jira email id as username and Api token as password.
Please take a look at this KB article.
https://confluence.atlassian.com/cloudkb/xsrf-check-failed-when-calling-cloud-apis-826874382.html
Yes I checked on this article as said in the article I added X-Atlassian-Token and value to no-check in the Header as you can see in the attachment, still it is not working.
Could you try running the command in with a command line tool? It might be the tool you are using.
