How can I create multiple subtasks for issuetypes Story, Bugfix and Spike? This was a feature in Jira on premise but seems to be no longer available in the Jira cloud.
This is not a feature on Server/DC, one of your admins set up an automation or script to do it for you. They can do the same on Cloud. I would try to do it with an automation, it's a lot more powerful on Cloud and is built-in.
Hi Nic,
Can you please highlight some details how to enable automation for multiple levels of subtasks for Jira CLoud.
Amna
It's literally adding several "create sub-task" blocks into the automation. There's nothing more to it!
Hi Nic, thanks for clarifying this. But I guess I'm missing something in the loop or unable to find the exacte triggers and actions. Attaching the snapshot of what I implemented.
Also, let me explain again. I want to create sub tasks of already created subtasks (3rd level of hierarchy) like child tasks of sub tasks. If you could spare out some time and help me in this then it would be great.
Amna
Oh, hang on, you mean you're trying to create a sub-task of a sub-task.
Jira does not support those, so there's no way to get an automation to do it.
Yeah, right. I thought I must be stating the other way round that you mentioned it's automation is easy.
No worries. Thanks for the help.
Sorry, I read it as "Create multiple sub-tasks underneath the current issue"
Okay. Thanks for clarifying. I'll contact our admin with a request to re-create the earlier on premise scripts in the cloud with Automation. Thanks for your help.
Welcome to the community.
You can try to achieve this with Automation. In on premise this feature was available with a plugin.
Show up and give back by attending an Atlassian Community Event: we’ll donate $10 for every event attendee in March!
Join an Atlassian Community Event!
