Hi all,
I'm struggling to create subtasks in our jira.
That said, I'm a little bit lost here and would like to get your ideas on this...
Many thanks, Julius
Button in Issue-Layout:
Issue Type Schema:
Hi Julius - What type of Project is this? Is it Next-gen?
Hi John, it's classic (and I'll stay classic due to big picture integration :))
Just stumbled into another hint: I tried to convert an existing issue to a subtask:
and it comes back with this outstanding message:
Where is the missing checkbox to acivate the subtasks...?!
See if this helps you:
https://confluence.atlassian.com/adminjiracloud/configuring-sub-tasks-818578898.html
That's it - the subtasks in general were disabled. Interesting that everything can be configured though the main-switch is disabled :)
Case Closed - many thanks for the very positive first impression of the atlassian community!!
Great ! that was i was trying to explain by "issue setting" ;D i'm happy you've fixed it ! enjoy
try to check if the subtasks are activated in your Jira settings .
Go to Jira -> settings -> issues -> subtasks
Hi Assia, yes - the subtasks are active for the schema used in the project (SC-Issues Type Schema)
