Could you please help me to create Dash board with below Condition and let me know the Gadget need to be used and Filters,
Showing
I’m Maurício, a support engineer at Digital Toucan and I’m here to help you.
About your two firsts questions, you can use these queries:
assignee is empty and issuetype in (Epic, BP, BPT)
issuetype in (Epic, BP, BPT) and “Solution Verification Target Start/Target End” is empty
Unfortunately, your other two questions are impossible using only Jira JQL. You can check a few apps in the marketplace that extend the search for you by clicking here.
In the app where my team works, JQL Search Extensions for Jira, you can use these queries to solve your requests:
issuetype = BP and linksCount = 0
issuetype = Epic and linksCount = 0
Please contact our support if you have any other questions about these queries.
We’ll be happy to help you!
Best regards,
Maurício
You've almost written the queries you need yourself - see https://support.atlassian.com/jira-service-management-cloud/docs/use-advanced-search-with-jira-query-language-jql/
Your first two are simple "issue type in (x, y, z) and not <something else", the third probably needs a function like "linkedissues" and the last one just needs to look at "epic link" or "parent" (depending on exactly what version you are using)
I can't suggest what gadgets to use - you've not told us what you want on the dashboard.
