Creating a dashboard using a filter which is querying from two different projects
Tobbe Wilson August 18, 2020
I want to create a filter (to be used by a dashboard) which is showing all tickets from the board CHM that are not Done, and are linked to any ticket in the board IIC which is in the status Live.
The query below shows all tickets from CHM, regardless of status.
project in (CHM, IIC) AND status != Done AND status = Live AND issueLinkType = "Is under improvement by CMH ticket" ORDER BY Country
 Anyone have any good suggestions?
John Funk
Hi Tobbe,
Maybe (project = CHM and status != Done) OR (project = IIC AND status = Live AND issueLinkType = "Is under improvement by CMH ticket") ORDER BY Country
Tobbe Wilson August 19, 2020
Thanks for your answer!
The OR gives me all tickets in CHM without that status.
Changing it to an AND gives no result
John Funk
What do you mean by "The OR gives me all tickets in CHM without that status."? It should only give you CHM issues that are not Done. Isn't that what you wanted?
Exactly, It should only give me CHM issues that are not Done, but it doesn't. I get all!
John Funk
Can you share a screen shot of that? Because that doesn't make any sense at all.   :-(
Sorry, my bad! I found a typo...
Like • John Funk likes this
Jira Guru
August 18, 2020
Hi @Tobbe Wilson
Project=IIC and status=Live and issuelinktype= "Is under Improvement by CHM ticket"
Save the above query as a filter. Say for example, Filter 101
Create another filter like the below and use it in your dashboard
Project=CHM and status != Done and filter in ("Filter 101") ,
Try the above and if that helps.
The first filter works fine and gives me actually the same results as i got from the beginning.
Project = IIC AND status = Live AND issuelinktype = "Is under improvement by CMH ticket"
But when creating the second filter, which is calling this one i get no hits at all.
