I'm trying to create a computed field on my issues that has a value computed from other fields.
For example, I have 3 fields:
- Width
- Height
- Depth
And I want to create a computed field named "Volume":
i.e.:
{{issue.Width * issue.Height * issue.Depth}}
How do I go about achieve this?
Hello @Lilly Mannerswood ,
With our Jira cloud app Dynamic Fields for Jira you can create dynamic fields that can extract and compute data from the issue and its history.
It is possible to create a computed "volume" field as you describe and use it for reporting and JQL. The expression for your custom dynamic field would look like this:
issue.customfield_10000 * issue.customfield_10001 * issue.customfield_10002
Make sure to replace the custom field IDs with the correct ones of your Jira instance.
If you need help in creating a custom dynamic field, don't hesitate to get in touch with our support.
Hi @Lilly Mannerswood ,
You need a plugin to do this. There is this post that explains how you could solve a similar problem using Scriptrunner:
Hope it helps,
Still thinking about joining us for Team '25 Europe? Early bird has been extended for just one week! Now’s the time to lock in your lowest rate. Use code TEU25COMM-20 to save 20% at checkout. Hurry, this only lasts for 1 more week.
Learn more
