Creating automatic issues with subtasks
W Abood November 16, 2023
I created an automation to create a set up standard subtasks every time an issue in a specific project is created. This works very well but there are 40 subtasks and I would like to break it down more by having the main issue with 5 linked issues that have their own set of subtasks. I've tried using branching but I cannot nest them. Is there another way to accomplish what I am trying.
Thank you
2 accepted
Mathew Lederman
November 16, 2023
@W Abood unfortunately Jira does not allow you to create subtasks under subtasks, so you'll have to use a different issue type for the 1 main and 5 linked. You may be doing this already, it's not very clear.
For creating the appropriate nesting, you'll have to perform multiple automations that are dependent on the first. Example: 1 Epic > 5 Stories > 34 sub-tasks. You'll need to build automation something like this:
  • The 1 Epic will trigger the creation of 5 stories
  • Each story will trigger the creation of 7 subtasks
This will create the appropriate nesting while keeping all of the creation in automation.
W Abood November 17, 2023
Thank you for the answer. I tried your suggestion and it worked well.
November 16, 2023
Hi @W Abood
With that many subtasks to create, you have a couple of options...
  1. Create one rule, triggered on your issue create, and add one of your linked issues, immediately followed by adding all the subtasks in one action
  2. Create 5 rules, each one triggered on the original issue create, and have each add their own subtasks
For the first method, try using branches to the most-recently-created issue, like this:
  • trigger: issue created
  • action: re-fetch issue
  • condition: you probably have conditions to decide when to add the other issues
  • action: create your first issue, linked to the trigger issue
  • branch: on most recently created issue
    • action: add all the child subtasks in one step for this issue
  • action: create your second issue, linked to the trigger issue
  • and so forth
Thank you for the response. I will try your method as well.
Like Bill Sheboy likes this
Get Certified! ✍️
