Creation of Multiple Sprints in Greenhopper
Kiran Reddy
We are evaluting the Green hopper for our product planing.
We would like to create multiple sprints at a time, could you please let us know how to create this.
Peter Cooper
If you go to GreenHopper Configuration in Administration, on the "GreenHopper Labs" tab, there's an option to enable "Parallel Sprints". That may be what you're looking for.
This feature was added in GreenHopper 6.0.3.
James Heggs
July 9, 2012
Hi there
Experiencing thing the same problem as Kenneth has mentioned here.
Does anyone know if there is an existing ticket against this feature that we can upvote?
James
Kenneth Willetts July 8, 2012
Rapid Board only link back to 1 project though. That project may involve many team; front-end, architecture, etc. I would have to change up my project structure to be able to build out sprints.
The issue is you can only create 1 sprint at a time. I may have two or three sprints running concurrently and GreenHopper can't account for that.
Kenneth Willetts November 18, 2012
So this is how I got it to work. Not easy
You create 1 masted scrum board. I use a simple filter on this board. Project = "X'
You then create another board scrum board for the sprint. The filter I give it is based on fixversion and project.
If I need a second board in the same project. I create ANOTHER scrum board referecing a different fixversion.
All of them show in the master board, but you have to go through the process of creating all the separate boards.
You can plan as many sprints as you want, but you can still only have 1 active sprint / board.
Thomas Unger
November 18, 2012
I did create two rapid boards, created sprints on each. I then started a sprint on board #2. When I went over to board #1 I found that it already had a sprint, the one from board #2, which one item which appeared on both boards. The item, A, was in board 2 sprint but not in board 1 sprint. Now I can't "start" the board 1 sprint.
We are not using strinct agile methodology. We are a small company with a few people working on multiple projects. "Sprints" are still reasonable ways for us to carve out and track a bit of work and it does make sense for us to have multiple sprints - that is just the nature of our work.
Tom
Thomas Schlegel
Hi Kiran,
create as many rapid boards as you want and then start a sprint on as many rapid boards as you want.
Look here: https://confluence.atlassian.com/display/GH/Using+the+Rapid+Board
or here: https://confluence.atlassian.com/display/GH/Starting+a+Sprint
Cheers
Thomas
