Cross team efficiency
Johnny Wong
Hi there
My boss has me looking for a function on Jira where we can make some graphic representations to show the multi-team efficiency in different projects. Currently I can only locate most apps with the function to show the number of hours spent on individuals like a HR timesheet. But we are looking for something to show the number of projects a team is carrying at one point so the senior management would understand the workload of different teams so would be able to readjust the resources if needed.
Would there be any function in Jira that rights a bell to you? Or you would recommend any app that would do this job?
Thank you.
2 accepted
3 votes
Danut M _StonikByte_
Hi @Johnny Wong,
See our blog article about How to track multi-team or scaled-agile projects (such as SAFeĀ®) in Jira with Great Gadgets app. This might help.
If you have additional questions, please contact support@stonikbyte.com.
Thank you,
Danut M.
Nhat Tu
June 11, 2023
Hi @Johnny Wong
Currently, there are some gadgets on Dashboard which show list all or selected projects. Ảnh chuĢ£p MaĢ€n hiĢ€nh 2023-06-12 lúc 11.21.56.png
Firstly, you need to go to the Dashboard > Search gadgets by filter 'projects' > Select the gadget of projects that you want to use.
I hope this helps!
Johnny Wong
Thank you.
Like • Nhat Tu likes this
