I have a custom field (Reproduction Steps). It should be a text field that allows rich text editing. I'm finding that it displays with the rich text editor for most projects but not for all.
I have the field added to my screen and updated in the layout for the project. I've also checked that it is available for use in the screens and context settings for the custom field configuration. Is there somewhere else I should be checking?
Not working:
Working:
It is because the rendering for that field is set to default instead of wiki style. You can change the renderer if you go to Project settings > Fields and edit the field scheme. Then locate the field and click on Renderer to change it.
