Hi All,
I know how to find the custom field ID usually, however I am trying to see if the cascading options have their own custom ID? I found the ID for the field as a whole and also the option ID's for the first option, are there id's for the second option and if so how do I find them?
Many Thanks
Jack
Hi Jack,
If you are using smart values in an automation rule it will look like this:
To get the value of the parent:{{issue.fields.Cascade.value}}
And for the child:{{issue.fields.Cascade.child.value}}
Hi @Jack Tucker
I locate it from the URL, by editing the sub-option in the cascade field options
You can see it here:
I can't always see the full URL by hovering over the "Edit" hyperlink, so I open the edit link in a new tab.
I assume it's also possible to get from the REST API.
Ste
