Am I going insane or not? I am trying to create new custom fields that are text field multi-line and that option no longer exists or I did something to hide it. I know it was there before because I have custom fields I created previously with that type but now I can only choose test field single line or a paragraph with rich text. I don't need rich text. How can I get this back or is it gone forever?
Hello @Colleen Gotling
You are not going insane. They just renamed the custom field type. If you select it, in the Custom Fields list it still shows as "Text field (multi-line)".
What did they rename it to because I am not seeing it where it should be and I don't see any other option that sounds like it would be the text field multi-line option. The only thing close is paragraph but I don't want rich text. Can I choose the paragraph field without the rich text?
Honestly I don't recall if there was both a custom field type for "Paragraph (supports rich text)" and another for "Text field (multi-line)" previously.
What I have discovered is that if I select "Paragraph (supports rich text)" as the field type, then in the list of custom fields it shows the field type as "Text field (multi-line)". So I assumed that the original custom field type was renamed as "Paragraph (supports rich text)".
Looking at custom fields I created months and weeks ago that show their type as "Text field (multi-line)" I see that they currently support rich text. Maybe they always did, or maybe Atlassian has changed from having two types of multi-line fields (one that didn't support rich text and one that did) to having only one type of multi-line field.
They definitely did not always support rich text but if it changed, then I just have to deal with it.
