×Hi,
I have a custom field which is used in multiple screens and I am trying to configure that field in my current project screen I am able to configure but I am unable to see the screen while Creating/Editing/Viewing the screen.
Sadhana
thanks for your question. If you are using a company managed project, there are a few possible solutions:
1. the custom field has a context, that is limited the the projects where you already used it. You can check that in Settings --> issues --> custom fields --> search for the field and hit the ... and select context.
2. It could be hidden in the project via field configuration
You can check that via Settings --> issues --> Field configrations and then selecting the one connected to your project and look for the field
3. It might be not displayed, because it does not have a value
Hope this helps.
Thanks a lot for the Answer. This works for me. Actually it was hidded in field configuration.
Sadhana
Hi @sadhana.chittibabu Can you please verify the field's context?
