Custom Fields Cleanup
Gaurav September 13, 2021 edited
We have very large number of custom fields which are needed to be cleaned up.
I want to merge same kind of fields without loosing data to get rid of custom fields.
As most of the fields are being used by different projects, what to take care of before deleting them?
Can anyone provide the checklist before proceed?
Peter Vandenberghe September 16, 2021
Looks like https://confluence.atlassian.com/clean/clean-up-your-jira-instance-1018788592.html is what you can use if your version of jira is not uptodate.
While https://confluence.atlassian.com/adminjiraserver/analyzing-the-usage-of-custom-fields-1047552722.html is better when you are at least on version 8.16.
Hubert Kut
Hi @Gaurav
If you are looking for help. I can recommend to try dedicated tool to cleanup and data governance. Doctor Pro for Jira which will do instance assessment and help you to execute it.
Hubert
Mayur Jadhav
Hi @Gaurav
Welcome to the Atlassian Community!!!
Please go through this article which will help you to get overview of what kind of things you need to keep on mind before and after performing cleanup activity.
https://confluence.atlassian.com/enterprise/managing-custom-fields-in-jira-effectively-945523781.html
Hi Mayur,
Thanks for your reply, Can you please guide me how do I see "issues" as that column is not getting displayed when I browse fields.
I have gone through and give superficial idea about cleaning the whole instance. I need to focus on only custom fields.
Thanks.
Gaurav
Ceyhun AlyeÅŸil
May 31, 2023
well those functions they mentioned works only on data center license. so we dont have it.
