Hi, I need a custom field that need to meet these requirements
- Allow different options in different projects
- Allow options to be disabled when necessary
- Allow only a single value
- Allow a default value to be configured
Any suggestion what type of custom field should I make?
Hi @Edward Quinito,
All your requirements can be covered with a select list (single choice).
Different options per project are managed by configuring different contexts, where you map each context to the corresponding project. In each context, you can set the available options, default value and disable options that are no longer valid.
Have a look at this support article for configuration tips.
Hope this helps!
