×Hi Team,
I am looking for custom report which gives information on issues got reopened how many times against each developers.
I am not finding this in JIRA. Please help me to get the required report.
Sayed
If you are ok with a marketplace app to get this data you can try out our app.
The add-on provides the time in each status for the entire lifecycle of the issue and you can filter by issue type as well. You can also combine your statuses to define your lead/cycle/resolution time and also extract the transitions history of the issues. The main features of the app are as below
Also there is a report for the dates when issue transitioned from one status to another.
Disclaimer: I work for RVS, the vendor for this app, and I am one of the developers of the app.
Hi Rahul,
Thanks for the information. I have installed the app and will come back for any help further.
Sayed
If you're comfortable with solutions from the Marketplace, I can suggest 2 developed by my team.
1. Issue History – journal for every past activity, including status changes. Here you can filter by assignee, reporter, project, date range, etc.
2. Time in Status for Jira Cloud will be even better in your case to find out how many times each issue has entered each status. There is a special report for this – Status Count.
Let me know if you have any questions.
Depending on what you mean by "reopened", you could do a JQL search based on the Status change. For example, if reopened means it went from a Done status to a To Do or In Progress Status, then you could use a JQL search similar to this...
Project=ABC AND Status CHANGED FROM (Closed) TO (Backlog, "In Progress", "In Test")
Keep in mind that the above example assumes the Workflow only contains Backlog, In Progress, In Test, and Closed Statuses (where ANY status can go to ANY status). It would need to be tweaked for your specific Workflow.
Once you have the Filter defined, you can export the results into Excel to Group/Graph the data, OR you can simply apply the filter to an Issue Statistics Dashboard Gadget and set the Statistic Type to "Assignee" (or whatever field you're using to track the Developer). This should give you a count of how many tickets were reopened for each developer.
Anyhow, just wanted to include this potential "out-of-the-box" solution. :) I hope this helps. Cheers!
Hi @Sayed Kamaloddin Peerzade,
There is a good solution for your request - Status Time Reports app developed by our team.
By default, it provides reports on how much time passed in each status. But it also shows status entry counts (in your case how many times an issue has entered "Reopened" status). You can also export the report as CSV and open it in Excel.
Here is the online demo link, you can see it in action and try without installing the app. Hope it helps.
Hi Support Team,
Thanks for the valuable input. I have requested for application but it says "App name not available"
Please help me to get the application access to it.
Sayed
Hi @Sayed Kamaloddin Peerzade ,
Your Jira admin can install the app over the Atlassian Marketplace using the try button from the below page.
https://marketplace.atlassian.com/apps/1221826/status-time-reports?tab=overview&hosting=cloud
Also, the eazyBI app provides options to count how many times issues have been re-opened or how many times.
One of those examples you can find in eazyBI Community posts: https://community.eazybi.com/t/how-to-count-issues-that-had-ever-been-reopened/3466/2
If you have any questions, feel free to contact us: support@eazyBI.com
Best,
Gerda
Can we install this tool for free of cost or is it chargeable. It Looks like there is a charge on this tool once free trial is over.
Hi @Hari Krishna Manepalli ,
Yes, the eazyBI app is a paid app, and after the free trial period ends there is a charge on it:
You can see prices here (you can select hosting you are interested in - Cloud, Server or Data Center): https://marketplace.atlassian.com/apps/1211051/eazybi-reports-and-charts-for-jira?hosting=cloud&tab=pricing
best,
Gerda
Thank you for the update.
I want to see just How many times the bug got Reopened. Is there any other solution other than paid tool.
Hello @Sayed Kamaloddin Peerzade ,
I have the solution for you. Our team at OBSS built Timepiece - Time in Status for Jirafor this exact need. It is available for Jira Server, Cloud, and Data Center.
Time in Status has many report types but particularly Status Count and Transition Count reports will help you. These reports show how many times each Status and each transition was used.
For all numeric report types, you can calculate averages and sums of report values grouped by the issue fields you select. For example, total re-open count per issue type or average reopen count per week, month, issuetype, request type, etc. The ability to group by parts of dates (year, month, week, day, hour) is particularly useful here since it allows you to compare different time periods or see the trend.
The app calculates its reports using already existing Jira issue histories so when you install the app, you don't need to add anything to your issue workflows and you can get reports on your past issues as well. It supports both Company Managed and Team Managed projects.
Time in Status reports can be accessed through its own reporting page, dashboard gadgets, and issue view screen tabs. All these options can provide both calculated data tables and charts.
And the app has a REST API so you can get the reports from Jira UI or via REST.
Using Time in Status you can:
EmreT
You can try to use the API and look at the history of your tickets to find which issue went to specific status and the author.
You can also look at the marketplace to find a suitable plugin.
