Custom fields: how to add a field of the same type as the time tracking
Assia Touati
Hi everyone,
Let me explain, I added two fields relating to statuses on my screen, and I want to use them to enter the time estimate for each status.
The problem is that these fields do not appear, even if I have configured everything correctly. Also, I wonder if it is not related to the type of the field, I put the type "time in status" but I can't see it. Can you help me please thank you
Magic Mike
March 17, 2020
Hi @Assia Touati
Actually "Time in Status" custom field type is rather a type of field you won't enter value in. This kind of field is used for Jira Charting Pluging. Once such field is added to a form, statistics values are entered to be the interpreted by the charting plugin.
https://community.atlassian.com/t5/Marketplace-Apps-Integrations/Information-about-Time-in-Status-field-used-in-the-Average-Time/qaq-p/412881
I would rather use in your case a text or number field.
Also the plugin : https://marketplace.atlassian.com/apps/1219732/time-in-status-for-jira-cloud?hosting=cloud&tab=overview is quite good to give information about time spent on each status.
Best regards,
Mike
Assia Touati
Thanks a lot for your explanations @Magic Mike , is there a way to capture the time of a status without a plugin ?
Upcoming Jira Events
