Custom fields types in company-managed projects
Sharee Charrett June 27, 2024
Creating a custom number field in a company-managed project, is there a way to remove the commas from the number format, it is currently displaying as 50,925,210, however, I would like it to be displayed as 50925210
Trudy Claspill
Hello @Sharee Charrett
Number field formatting is based on your language setting. You can't otherwise customize it. There is a change request about that here:
https://jira.atlassian.com/browse/JRACLOUD-45545
An alternative would be to use a text field and add validators and/or automation rules to ensure that the contents are only a number.
