Custom web item with Run code does not work?
ChrisR
When using the "Run Code..." option I would expect to see a way to enter the code to be run and a reference to a flag or dialog. Neither are given, the link field remains. Is this an error in the ScriptRunner add-on? Is there a workaround?
PD Sheehan
May 24, 2020
I can see how that label could be misleading.
This is not an error.
Perhaps better labels would be
  • Navigate to Link
  • Call REST api and display a Dialog
  • Call REST api and show a flag
  • Do nothing.
In either case, you have to write a custom REST enpoint that will return either a Dialog HTML or a flag json object.
You can find an example to get started here: https://scriptrunner.adaptavist.com/5.7.1.1-p5/jira/fragments/WebItem.html#_dialogs_advanced
