×Hi! I have a workflow schema for issue type Story which has 6 statuses. We are also using Subtasks, for which I'd only like to use 3 statuses. Is it possible to use different workflow schemas for different issue types? So far I've only been able to use the same one for all issue types.
Thank you!
You can modify your workflow scheme to
This is in in Jira Settings -> Issues -> Workflow Scheme.
awesome thank you!
