×Hi there,
I am wondering that if I can config the column in the sub-task block. Like the red box in the screenshoot showned below.
You can see that there are four columns in the default sub-tasks block, summary, issue type,status,assignee. But I want to add another column like 'Story Point' into this block.
Maybe someone has an advice?
Hi @Will You ,
https://support.atlassian.com/jira-cloud-administration/docs/configure-advanced-settings/
Whoops - I didn't mean to make this an answer. It's an additional question...
I can't find this in Cloud version. jira.table.cols.subtasks
Is it not available? Or is it possible in another part of the Settings?
You have to go to admin setting for Jira
Then you can find the advanced setting in the right upper corner.
You can see the setting for subtask column list.
Be careful, this setting is Global. It will apply all project all subtask list.
I went to this area and that option is not on my screen.
The order of the columns on my Subtask list changed with no warning and I wanted to see if I could change it back, but the option above is not on my screen.
Was just checking this today as well, yeah, I don't see jira.table.cols.subtasks either.
According to a response further down in this thread, the option is not available in the cloud version. I wonder if someone made a global change in the cloud version on some of the Subtask displays that is affecting everyone that uses the cloud version.
Hi @Ollie Guan
Tried adding Story points as mentioned in the above comment, unfortunately I'm getting this error? Kindly assist
I know it's a late responce, but in case anyone have the same question - you should put custom fuels in customfield_<number> format in this form.
E.g: issuetype, status, priority, assignee, progress, customfield_11111
I'm sorry for the off topic, but I suppose it can help someone, this feature isn't available for now in the cloud: https://jira.atlassian.com/browse/JRACLOUD-70206
