I have a team-managed project with 4 states in the kanban board (TODO, WIP, WAITING, DONE) and I have enabled the backlog option.
By default, the tasks in the backlog are in the same state as the tasks in the TODO (one on the columns of my board), but I would like to distinguish between them and assign them two different states. Is there any way to do this?
Hello @icalvelo
With a Team Managed project Kanban board the issues on the Backlog screen are divided into two lists. The lower list is labeled "Backlog" and the upper list is labeled "Board".
Issues can be in ANY valid status and appear in EITHER list.
That is by design for Team Managed project Kanban boards.
To have an issue appear in the Board view you have drag it on this screen from the Backlog list below to the Board list above.
New issues created with the Create button from the menu bar will automatically be added to the Backlog list. If you want a new issue to go directly to the Board, use the +Create Issue option that appears at the bottom of the upper Board list.
You cannot customize this so that only issues in specified statuses appear in the Backlog list. That is only possible with Company Managed projects.
Hi @icalvelo
I guess, this discussion can help to solve your issue: https://community.atlassian.com/t5/Jira-Software-questions/How-to-Customize-Backlog/qaq-p/2149765
I've already seen that answer but it doesn't work for me because it is only for company-managed projects and I have a team-managed projects
Welcome to great meetings, with less work. Automatically record, summarize, and share instant recaps of your meetings with Loom AI.
