Hi!
We create epics and then using the "Create issues in epic" button we create several issues.
We can change Status, Assignee in the "Issues in this epic" section. (in the attachment)
Is it possible to customize this card layout?
It would be great to enter "Original Estimate" in this place without opening the "Issue screen"
Best regards,
Vladimir.
If you would be interested in a third party add-on, you can try out our app.
Agile Tools - Epic Tree and Time in Status
It will provide you the complete Epic Hierarchy on the Issue screen itself, with option to update Estimates and Story Points fields, right there on the Issue Screen.
