Dashboard Gadget missing
Pooja.Aswanth September 17, 2021
Hi Team,
We have recently found that one of the gadget in a dashboard has disappeared which displayed just one row with total number of tickets assigned to me. Is there anyway to recover it?
One more issue that appears to happen is that the gadgets moved from left to right, fails to be saved as a new layout. The refresh dialogue box appears in the left corner and old layout appears back.
Any help/tips appreciated.
Mayur Jadhav
Hi @Pooja.Aswanth
Welcome to the Atlassian Community!!!
 I am not sure which dashboard you are talking about System Dashboard or Personal Dashboard which you have created.
If the System Dashboard your are talking for this you need Jira Admin Global Permission. If you have that permission just go to the manage dashboard, open that click on Add gadget then search for Assign to me gadget. Now you can select which column you want in that gadget. Similarly there is one option called change layout you can change it as per you need.
Hope this helps you.
Mayur
Pooja.Aswanth September 18, 2021
Thanks @Mayur Jadhav  for your response.
We had a personal gadget visible to our team which is missing from Team's dashboard since few days. The Assigned to me dashboard just had no of tickets assigned to each member. Is there a gadget type that I could use to re-create just to display number of tickets assigned?
I do have a change layout option, but when used failed to save the changed layout.
Pooja
Carlos Garcia Navarro
Hi, can you please attach a screenshot? Thanks!
Pooja.Aswanth September 19, 2021 edited
