Dashboard gadgets available
Leanne Viljoen November 13, 2023
Are their additional dynamic dashboard gadgets available for purchase apart from the standard bar and pie charts?
Marlene Kegel - codefortynine
Hi @Leanne Viljoen,
I am Marlene, product manager of Quick Filters for Jira Dashboards.
By "dynamic" do you mean that you want to be able to dynamically filter the gadgets on your dashboard? If yes, you could check out our app Quick Filters for Jira Dashboards.
Our app comes with a Quick Controller gadget, that enables you to filter the results which are displayed on your gadget. You can create custom buttons, drop down filters or input fields on the controller gadget.
You can check out our app without installing it, on our demo dashboards.
Teodora V _Fun Inc_
Hi @Leanne Viljoen
As @Rilwan Ahmed suggested, you can browse the marketplace for apps that suit your needs. However, I can't escape mentioning the reporting app made by my company: Custom Charts for Jira.
One of Custom Charts gadgets, called Simple Search, allows you to dynamically filter data based on customized requirements.
You can watch an explainer video about it here:
https://youtu.be/KMiSRcyD-KI
Hope it helps :)
Rilwan Ahmed
Hi @Leanne Viljoen ,
You can search for any required charts in Atlassian marketplace, use them for 1 month as trial and buy if it satisfies your requirement
https://marketplace.atlassian.com/search?hosting=cloud&product=jira&query=charts
Ivan Garcia _Appfire_
Hi @Leanne Viljoen
As other vendors have suggested, I'd recommend navigating the Atlassian Marketplace to find what best satisfies your reporting needs :)
If you want to start somewhere, I'd love to mention our amazing app Dashboard Hub for Jira – Custom Charts & Share Reports, which includes nearly 100 pre-built gadgets and allows customers to achieve awesome things as saving 150+ hours a year.
Hope it helps!
Leanne Viljoen November 23, 2023
Looks good, thanks
Danut M _StonikByte_
Hi @Leanne Viljoen,
There are many 3rd party apps on the Atlassian Marketplace that offer dashboard gadgets.
Our Great Gadgets app offers many gadgets for tracking projects (Scrum, Kanban, SAFe, ISTM, etc), as well as general purpose gadgets.
Hope this helps.
Danut.
Sanjen Bariki
November 13, 2023
Welcome to Atlassian community!
Please find the below atlassian document for the all pre-installed gadgets.
Take a look into the document as per the requriement.
Accept the answer If it helps you😊.
Sanjen
