Database configuration for Java Melody - problem with parameters (connection pool)
Wojciech Miecznikowski October 25, 2018
I connected Java Melody to the Oracle database. I must changed configuration like below:
dbconfig.xml:
<jira-database-config>
<name>defaultDS</name>
<delegator-name>default</delegator-name>
<database-type>oracle10g</database-type>
<jndi-datasource>
<jndi-name>java:comp/env/jdbc/JiraDS</jndi-name>
</jndi-datasource>
</jira-database-config>
additional lines in <Context> in server.xml:
<Resource name="jdbc/JiraDS" auth="Container" type="javax.sql.DataSource"
url="jdbc:oracle:thin:@//YYY:1525/XXX"
driverClassName="oracle.jdbc.OracleDriver"
username="jiradbuser"
password=
minIdle="20"
maxActive="40"
maxWaitMillis="30000"
minEvictableIdleTimeMillis="60000"
timeBetweenEvictionRunsMillis="300000"
maxIdle="40"
removeAbandoned="true"
removeAbandonedTimeout="300"
and Java Melody working fine, but every settings are default, so my connection pool size is not 40, but 8. Do you have any idea why?
Ronak
Hello Wojciech Miecznikowski,
You should have to use maxTotal="40"
password=
minIdle="20"
maxTotal="40"
maxIdle="40"
Wojciech Miecznikowski October 26, 2018
anyone have any idea? I can not find correct configuration
