Hi everyone ,
Is there a way to make 1-3 components as default for a project, so there is no necessity to add them each time . For example I have a project with 5 components, while 2 of them are always used ,the others not, want these 2 to automalitacly appear on component field.
Thanks in advance
You could do this using Automation.
To create this on a project-level, you'll need to be a Project Admin and then...
^ This will work for all issues created on the project.
You could refine this rule if needed - for example, if this was just for Stories, you could add a Condition (such as Issue Fields Condition) between the Trigger and Action to check if Issue Type equals Story.
Ste
Thanks for such detailed answer, will do it for sure.
There is not a way to do this OOTB. Consider an addon. I have seen Project Creator mentioned previously (no personal experience) but it is for Server/DC only. There might be others.
Thanks, know about Project creator, but as you mentioned it is not for cloud , Will check other addons availabe in marketplace .
