I'm deeply confused as I'm not finding a way to delete an attachment from an issue. There is no waste bin icon showing up on the attachment that I want to delete.
According to the rights scheme, I have the right to delete at least my own attachments.
Do I miss more access rights?
In case someone else lands on this thread... I was stumped on this as well, but apparently you cannot delete an attachment from the attachment section if it was added via a comment. This is expected behavior per atlassian docs.
see Attachments in comments section:
https://support.atlassian.com/jira-software-cloud/docs/delete-an-attachment-on-an-issue/
If your attachment is there as a drag and drop into another field then you have to edit the field to delete the file.
@Michael Marriott Could you explain what do you mean by drag and drop field ? I do not have the option to delete either. I am the org admin and the user who added the attachment is unable to delete it as well. Please advise.
If you are able:
Hi @Del Jensen
I've consulted the permission helper and it shows me, that I have the permission to delete my own attachments and all attachment.
Nevertheless, I don't see the trash bin and also don't see the entry to delete all attachment in the action menu.
I see a trash bin in both CMP and TMP projects. What screen are you viewing?
it's a CMP and I' viewing the new issue view that opens up inside a modal. The trash bin is also not visible in the issue view if I access the issue by a link.
I see the image below. Please verify that you have delete all or delete own attachments depending on needs (project settings / permissions).
I suggest you create a new issue and add an attachment then see if you can delete.
Thanks for you support! I've also created a test project and can't reproduce this behavior in the new project. Attachments can be deleted... Permissions seems to be granted correctly.
What I further found out is, that this somehow is related to a specific user account that is the author of the corresponding issue. The creation of a new user with exactly the same groups that this user has lets me reproduce that.
We follow in general the suggestion from Atlassian by using a dedicated role ("Browse") for accessing specific projects. The permission for delete own is granted to this role. The permission for delete all is granted to administrators.
What I don't understand is that even with my user account (administrator) the trash bin is not visible for attachment that this specific user did upload.
Hmmm, that is odd. So it seems there is some super-user that has protected content that others can’t touch? I would suggest reaching out to Atlassian support directly on this one as I am stumped. If you do this please update the post with the final resolution
