I have two projects X&Y, which will have multiple issues like EPIC>>Feature>>Story>>Task>Sub-task/s, in a structure.
Some of the Issues in each of these projects are blocked or depends which I am trying to show in a column by using below logic:
issueLinks.type.filter(array("Blocks").contains($)).
But the problem is - for some of the rows (different issue types) - entries in the column showing dependencies multiple times like - blocks, blocks, blocks etc
Ex:
EPIC ---- Blocks, Blocks - my understanding is - since child entries of EPIC having blocks - here structure showing blocks more than once.
Feature - Blocks - means if i understand correctly - Feature is blocking EPIC
Stroy - Blocks - means if I understand correctly - Story blocking feature
My requirement is I want to show 'blocks' only once at EPIC/feature/story level though child entries have blocks.
Appreciate any help here.
Hello @sarathgd ,
David from ALM Works here.
For this, you will want to use the UNIQUE function. The formula below should work for you.
issueLinks.type
.FILTER($.CONTAINS("Blocks"))
.UNIQUE()
Please let me know if this helps.
Best,
David
Thanks David this really worked.
One more question is - if I have to filter out one more dependency type like 'Depends" can I use same approach?
issueeLinks.type
.filter($.contains("Blocks","Depends"))
Unique() ??
Hello @sarathgd ,
We just need to adjust the FILTER slightly. This should work:
issueLinks.type
.FILTER($ = "Blocks" OR $ = "Depends")
.UNIQUE()
Please let me know if it helps.
Best,
David
Thanks David for quick help here. Now the structure shows Blocks and Depends when ever there is any dependencies.
By any chance will there be any case like both Blocks and Depends applicable between any issues type? Can that be achieved like -
$="Blocks" AND $="Depends"?
If apply this logic, none of either Blocks or Depends are appearing in the structure.
Hi @sarathgd ,
You are very welcome.
The formula should do, and does in my testing, the following:
IF there is at least one "blocks" link and no "depends" link: "Blocks"
IF there is no "blocks" link and at least one "depends" link: "Depends"
IF there is at least one "blocks" link and at least one "depends" link: "Blocks, Depends"
IF there are no "blocks" and no "depends" link: (blank)
(for all four, ignore other issue link types)
Is it doing something different for you?
If it is doing something different, you will want to contact our support team directly to review the behavior and identify potential causes. You can reach us via email support@almworks.com or through our customer portal support.almworks.com.
If it is doing what I describe above, then we will need to review your use case in more detail to understand all of the variables and end goal. Here too it may be best to contact our support team directly.
Best Regards,
David
Thanks David for quick reply, I'm looking for logic if issue have both blocks and Depends.
Hello @sarathgd ,
This should work:
with link_filter =
issueLinks.type
.UNIQUE()
IF link_filter.SIZE()=2:
link_filter
It looks at the number of elements the original formula returns and if it is = 2, then it returns the values.
Best,
David
Hey friends! - fellow begginer Jira user here, I sue
Initiative (main project) ¬ Epic (Main workstream header) ¬ Stories ¬ then tasks.
Collaboration with other teams often involves them creating related stories and tasks in their respective Jira projects.
While I can link these tasks via issue linking, a critical limitation arises: I cannot establish dependencies between these linked tasks and my primary initiative's tasks, nor do they appear on my main project plan.
Is there a way I can achieve this on a formula?
Is it feasible to incorporate these external tasks as dependencies and visualize them within my project plan?
