Despite having completed issues, the Sprint is marked as 'unresolved
정예솔
March 16, 2023 edited
I have marked all the issues under the Sprint as 'completed(Done)'.
However, when I clicked on the 'Sprint Complete' button, a popup window showed that the issues are still 'unresolved'. How can I make the transition to the 'resolved' state possible?
Screenshot link :
https://xd.adobe.com/view/24a030a9-a553-44b2-a928-8cddf3fb2e89-71f3/
David A
March 16, 2023
Hello @정예솔
Sprints doesn´t  use resolution or status as "done" - it's based on what is in the last column on the board.
Review your board and set last column  your Done status.
I hope this help!
정예솔
March 16, 2023
Thank you for your help. It completely resolved my issue.
David A
March 17, 2023
Great! It would be of great help if you mark the problem like answer accepted .
Best regards!
FREE
